跳转到主内容
Altec Lansing, Inc. is an American audio electronics company that primarily produces loudspeakers and associated audio electronics for professional, home, automotive, and multimedia applications.
9 个问题 查看全部
power light doesn't come on the control speaker.
Altec Lansing ADA747 computer speakers
Speakers have on audio out. The power light doesn't come also. The fuse on the sub woofer is good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
post some pictures inside for us to see.
Front PCB and and Back PCB
Do you have a multimeter?
If unsure, bring it for a friend or shop to check.
完成的
添加一条评论
1个答案
The large round multi pin plug as to make good enough connection to supply power and often doesn't with age. Wiggle it until it at least flashes the light r you give up. If it does the issue is that connector pair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 740
