跳转到主内容
First generation Bose SoundLink Mini released on July 1, 2013. The device weighs 1.5 pounds and has a Bluetooth range of 30 feet.
46 个问题 查看全部
问题已关闭
I am having trouble with Bluetooth pairing on the SoundLink Mini.
My device will not connect/pair with the speaker (or the speaker can't find my device). I want to listen to music, but it just will not connect. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
1. Make sure the software on your speaker is up to date.
2. Reset your speaker using these steps: On the speaker, press and hold mute for 10 seconds, the LEDs will flash briefly. Then press Power to turn the speaker back on.
3. Make sure your device is within 30 feet from the speaker.
4. Make sure your device is in bluetooth mode.
5. Check your devices pairing list and make sure your speaker is the one selected.
这个答案有帮助吗?
得分 0
1条评论:
Spot on worked first time really appreciate this as I was close to consigning the little chap to the dump!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 236
