跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
Water damage LCD not displaying
So i dropped my phone in the toilet, and it took me about 5 seconds to figure it out and remove it, stupidly i thought iphones were water proof after watching ytube videos of them being fin after 30 mins of being submerged, so i contie using it for an hour o listening to music, then when i got back i charged it and at some point there it died and would not turn back on.
so i left it to dry for a day and a half, and now i can turn it on, but when i try to restore it on itunes i get error code 1, and the LCD is blank, i checked it in pitch black conditions to see if it was the backlight, but i still cant see anything, any ideas, would replacing the screen fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
is there any chance apple will repair or fix it for free?
完成的
添加一条评论
5个答案
已选择的解决方案
John Price, first off it's water damaged so no Apple will not repair/replace it for free. Second, as with any other liquid immersed device you need to follow a few steps for proper trouble shooting.
stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.
The very first step I would take is to disassemble your phone. Use this teardown to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. Hope this helps, good luck.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 6s图片
指南
iPhone 6s拆解
难度:
中等
这个答案有帮助吗?
得分 1
2条评论:
is 100% too strong? and can i replace the battery with an iphone 6 one?
完成的
100% is perfect. As for the battery, I'd stick with one that is meant for your model.
完成的
添加一条评论
最有帮助的答案
Error code 1 is usually about the cord that you're using. My guess, in this case, is the Lightning dock. If the screen is blank, but it's still on, you can do a force restore. If the display assembly is indeed damaged, you could replace it. I wouldn't update to a new iOS though...
iPhone 6s 屏幕更换
You may have difficulty finding new parts, so soon, for this phone. Maybe need to wait another month?
这个答案有帮助吗?
得分 2
添加一条评论
I would open it and make sure its completely dry of any liquid, then continue with troubleshooting. Continuing to use it with potential liquid in it, could further damage it.
这个答案有帮助吗?
得分 1
4条评论:
He's actually totally right. I guess I didn't think of that. Clean the logic board and the sockets with isopropyl alcohol. I would use 90 proof
完成的
once i get the alcohol do i just pour it on a cloth and wipe the board?
完成的
You technically should disassemble the phone. Remove the logic board, battery, etc, and clean throughly. I would also make sure all liquid is gone off connectors, etc. This is good that you caught this sooner, than later. While the liquid is still wet, its much easier to clean, opposed to when its dried, and caused corrosion.
完成的
Yeah. Take the board out, then pour the isopropyl onto a clean toothbrush, then use the toothbrush to clean the board
完成的
添加一条评论
Open the phone clean with IPA look at the water indicators replace them and go straight to the Apple store. If done correctly they shouldn't know it has touched water/won't check deep enough to notice.
这个答案有帮助吗?
得分 0
4条评论:
However they will know that it was opened if this is a 6S
完成的
Didn't realise it was a 6S.... %#*@, that sucks.
完成的
how will they know for 6s and not 6?
完成的
The phone is already water damaged. He is going to have to pay no matter what. Unless he has Apple Care.
完成的
添加一条评论
Bad battery is too bas
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Price 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 41,586
