跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
492 个问题 查看全部
Sparked Motherboard and Smoke?
My iMac recently made a loud pop noise and about 2 minutes later it smelled like smoke but was not coming out! I don't know if it was a spark in the motherboard or not, and if yes I am scarred because I had a lot of stuff on that computer. My grapics card had to get replaced but I haven't yet. And it has been about 3 months since I have turned it on and I wanted to transfer data to external hard drive but now I think I can't. Please Help!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
This sounds like a blown capacitor, diode, or other similar component. There is a strong possibility that your hard drive is still working. Disassemble the computer using one of the many guides on this website and remove your hard drive . Put the hard drive in an external dock (you can buy them online for ~$20) and attach it to another computer to extract the data. Alternatively you can find the circuit board with the damaged component by looking for burn spots surrounding a missing or damaged component. Once you locate the damaged circuit board you can try replacing it. Keep in mind that if part of the power supply is damaged then it probably took the other components with it like the motherboard, processor, and even hard drive. Because of this possibility I highly recommend checking to see if the hard drive is working before you attempt a full system repair.
这个答案有帮助吗?
按维修分数 1
评论:
Thank you!!!
添加一条评论
添加你的答案
Elias S 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 226
