Glass replacemen for iPhone 6s
Is this different than iphone 6 glass? Lcd still good just need to replace cracked glass. Can't find anywhere that tells me they are same or different
The differences are very minute, but they are not the same product. The 6S Glass panel will be stronger than the 6, to cater to the Force Touch function, so that the screen does not crack.
It is not recommended in any Technicial field to mix and match parts for different models, even if they come across as identical
Regards
这个答案有帮助吗?
5/5C/5S glass? or 4/4S? they're interchangeable
The Lenses, yes, but it is not recommended
lol, by whom? The glass is exactly the same strength/thickness etc. They all use the same variation of gorilla glass and the same camera lens. Why is it not recommended? they didn't create 3 different types of glass, there's only one
@Stephen I don't think so he will buy an glass with same parameters like it is original in i6s
这个答案有帮助吗?
OEM iPhone 6S glass is not the same os OEM iPhone 6 glass. You may be able to get away with using 6 glass on a 6S screen but I don't know any professional that would do that.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 802
2条评论
Hello,
I would just replace the screen as a whole (with the glass). Theres a higher probability of doing damage to the screen with just trying to replace the glass. Replacing as a whole; the only thing you need to do, is swap some parts over.
由 Pat Yakis 完成的
Well no one around here can do that repair yet tell me parts not avaliable. Not paying 400$ on ebay for whole display piece. So guess ill pay apple 130$ to fix it at store. Thanks for feed back guys
由 Kosmo42o 完成的
