第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3260 个问题 查看全部
little sound shaking the device gently
Hi.
Shaking gently my Iphone 4 i can hear a little sound as like a screw, which isn`t fixed. Pressing the "sleep button" on top of the device and shaking it, the sound isn`t hearable.
Do you have an idea wherefrom this sound comes?
Thanks.
Gabriel
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
You said it sounds like a screw which isn't fixed - did you open your iPhone / do any repairs before this happened? If so, what repairs?
Hi. I didn`t either repair or open the Iphone. My question was morelike, if you can imagine the reason for the sound.
Thanks!
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
Gabriel, I tested this with an iPhone 4, the sound that you are hearing when you shake your phone is in fact just the sleep button itself. This is why the noise goes away when you hold the sleep button in place. You in fact don't need to push the button down all the way to stop the noise, you can just hold the button still with your finger. This seems to be true of all iPhone 4's - there's nothing loose, or wrong with your phone at all. Good catch though!
这个答案有帮助吗?
按维修分数 3
添加一条评论
It could be the iPhone's vibrator that you hear when you shake it.
这个答案有帮助吗?
按维修分数 0
评论:
Hi, in my opinion the vibrator isn`t located on the left side of the device. And:
Pushing the sleep button on the left side of the Iphone while shaking it gently make the sound insist. So my question is, if you can imagine a reason or mechanism that explains that the sound is terminated when I push the button.
Thanks
The vibrator is in fact on the top left corner of the iPhone 4, when the device is viewed from the front. For proof, check the guide Matt linked. :) The reason it looks like the vibrator is on the top right in the guide is that in Step 3, the device was flipped over to access the rear panel.
Okay, thanks. Another aspect.While shaking it and hearing the sound AND pushing the button (during shaking!) the sound DOES continue.
添加一条评论
in my teardown, the same sound continues but is coming form the logic board, under the EMI shields, toward the bottom!!??!!
这个答案有帮助吗?
按维修分数 0
评论:
What you're describing is something different than what I've heard in the past - you may want to check and make sure nothing is loose inside.
添加一条评论
I think it is the camera lens, since this is autofocus, mine is doing it too also when I put it on the table.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Gabriel 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 5,342
