跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
Is the iPhone 6s waterproof?
The other day I droop my friends iPhone 6s into water and it seems work as usual for these days.Some body say iPhone 6s is waterproof on the internet. But I haven't seen any official word. So is the iPhone 6s waterproof?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
iPhone 6s and iPhone 6s Plus water resistance better than last year's iPhone, but can not be truly waterproof. it isn't waterproof in the 4 feet depth water.http://www.hcqs.cc/
完成的
添加一条评论
8个答案
已选择的解决方案
There are some improved splash/shower protections, however the device is not rated waterproof so water can still leak in, especially when submerged.
这个答案有帮助吗?
得分 10
2条评论:
Thank you for your answer!
完成的
I shot my iPhone 6s with a water gun, don’t ask why
完成的
添加一条评论
All waterproof phones with a high parameters are 3 time thicker than iphone 6s :) Btw. theres no phone what is fully waterproof, their are only a lil bit more resistant on water than for example iphone.
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
No, and apple will probably never make an iPhone waterproof.
这个答案有帮助吗?
得分 1
2条评论:
Ha ha ha . Never say never
完成的
Little do they know. Ahh the good old 2016 days
完成的
添加一条评论
Apple made the iPhone 6s nearly waterproof and didn't tell anyone. Apple packed in a new gasket around the sides of the phone, and it incased every cable connector on the phone's logic board with a waterproofing material. Given that the logic board that includes most of the iPhone's sensitive electronics and is the most prone to water damage, Apple's solution is particularly clever.
这个答案有帮助吗?
得分 1
2条评论:
I don't think so it's just added water resistance. I've had an iPhone 6s dropped into toilet water by accident and taken it out quickly then tried out. Looked like no liquid actually went in the phone so yeah there is some water resistance to stop liquid from coming in but no way it is nearly waterproof.
完成的
I dropped mine in a 6 inch deep creek and it worked fine but the sound will not work
完成的
添加一条评论
So far I have found that the iPhone 6s is partly water proof you can take it into the shower and get it partly wet but I wouldnt recommend taking it all the way into the pool or dipping it into a sink or bucket full of any liquid
这个答案有帮助吗?
得分 1
添加一条评论
I accidentally dropped my 6s+ in a bowl of water in the kitchen. I pulled it out within seconds. That was 3 days ago. No problems and extremely thrilled.
这个答案有帮助吗?
得分 1
添加一条评论
It's water resistant and has an adhesive around the screen to protect it.
这个答案有帮助吗?
得分 1
4条评论:
The iPhone 6S is not spec'd as being water resistant. Apple experimented with the adhesive and as such, it is much better at keeping water out than the iPhone 6 but it's important not to spread mis-information.
完成的
Ah, I heard it the adhesive makes it water resistant. Probably should've looked into it a bit more.
完成的
No worries, it's a common misconception. The adhesive is just one part of the solution that Apple implemented in the 6S and above. There are also gaskets around the connectors and additional sealing around all of the points of entry. It was only with the iPhone 7 that Apple officially recognized it as being IP67 water and dust resistant.
The iPhone 7 is splash, water, and dust resistant and was tested under controlled laboratory conditions with a rating of IP67 under IEC standard 60529 is water-resistant. Splash, water, and dust resistance are not permanent conditions and resistance might decrease as a result of normal wear. Liquid damage not covered under warranty - per Apple
完成的
What does IP67 mean?
* Dust tight - No ingress of dust; complete protection against contact (dust tight). A vacuum must be applied. Test duration of up to 8 hours based on air flow.
* Immersion (up to 1 m depth) - Ingress of water in harmful quantity shall not be possible when the enclosure is immersed in water under defined conditions of pressure and time. Test duration: 30 minutes. Tested with the lowest point of the enclosure 1000 mm below the surface of the water, or the highest point 150 mm below the surface, whichever is deeper.
完成的
添加一条评论
When I was at the pool with my iPhone 6s I accidentally dropped it in so than when I took it out t was working I was so surprised
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Welson0624 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 20,448
