跳转到主内容
修复你的物品
维修的权力
商店
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
59 个问题 查看全部
Why does my device fail to turn on?
When I first bought this laptop, it worked fine, but over some time, the battery life got shorter and shorter, and now it won't turn on. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
It sounds like the battery needs to be replaced. Refer to this guide here:
Asus X555LA-SI305041 Battery Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex Turner 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 274
