跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 个问题 查看全部
PSP 2000 start button does not work. help! >_<
hi! i got a problem with my psp 2000. The start button does not work. Instead i use the "ON and HOLD" switch to use the "start function". i guess its kinda unusual how that happened but it really did. I dont really know what might be the problem. the problem might be from the software or maybe from the hardware. Anyway, is there I can fix this? Its really annoying to use the method of switching to "HOLD" and then switching to "ON" just to start a game. Well thanks in advance! ^^
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Take off the case and unplug the circuit board that goes to the front buttons. Check and make sure he little nub on the start button didnt break off. Then re-insert fully and try it again. With it all off try to hit the button on the circuit board without using the actual button to see if it works.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Des Pae Cable 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 36
总计 10,497
