My Nexus 6 battery will not charge
Hey, so I performed a glass-only repair on my Nexus 6 (I run small repair business). All went well, the display looks/ works fantastic and everything works fine except the battery.
Nothing seems to have been damaged, but the battery will no longer take a charge. I've tried the Moto turbo charger, PC USB, Samsung chargers, all the same issue.
The device will absolutely happily work while plugged in...it just won't charge the battery. The battery just 'flat-lines' no charge / no depletion. The charging bolt shows on the icon, but status shows 'Not charging'.
I successfully flashed the latest Android 6 via USB cable. I have wiped and formatted everything. I did notice that it was charging (went from 10% up to 34%) while booted into TWRP custom recovery whilst doing a backup - but since I restored stock > updated Android 6 > flashed latest TWRP it no longer charges even in TWRP recovery.
I have let the battery deplete and automatically power off, then left on charge for a few hours but it still won't take a charge. The device boots up with 1% and will just happily work forever on 1% while plugged in.
Any ideas?
1条评论
I have been using Motorola Nexus 6. Now it Shows some problem like while charging mobile it shows charging where as in real the battery does not charges at all. I ever replaced charging jack & battery with new one but problem still persist. you are help me resolve the problem.
由 Irfan Maimini 完成的
