跳转到主内容
Released in September 2012, the Le Pan S has a 9.7” screen and is identified by the model number TC978.
7 个问题 查看全部
Why won’t my Le Pan S charge when it’s plugged in?
My Le Pan S tablet will not turn on. I repeatedly hold the power button, and I still have a blank screen. When I plug it into the wall, nothing happens
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
My tablet won't stop deleting its like it stuck on deleting.
完成的
the pad is not coming on when charging it
完成的
添加一条评论
3个答案
已选择的解决方案
Try plugging the charger into multiple outlets to make sure the issue does not reside within the electricity being supplied to the outlet. If you have no luck, consider using a friend’s charger or purchasing a new charger to charge your device. If the issue persists, the problem you are experiencing is most likely due to internal components such as a battery. Please see a troubleshooting page located at Le Pan S Troubleshooting.
这个答案有帮助吗?
得分 1
添加一条评论
After trying multiple solutions including purchasing new cords, pressing the reset button and other online fixes i resorted to opening ours when it refused to charge - i disconnected the battery and then reconnected it problem solved and the tablet works again
这个答案有帮助吗?
得分 1
1条评论:
My lepan is in a different language.. how do I change language to English if I cant read the language it s in...bi
完成的
添加一条评论
I have a new charger and I have never used this le pan its been sitting unused for years because we lost the charger then lost the l pan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wiaam Elkhatib 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 4,305
