跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
571 个问题 查看全部
LCD has a gray bar of pixels after digitizer replacement
Hello! I have replaced the digitizer on an iPad Air, and the top rows of pixels are grey after that. It is about half a centimeter of mostly gray pixels, but below that, the screen works just fine. What can have happened?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Probably didn't connect it properly. Could possibly be a bad part
iPad Air Screen Digitizer
iPad Air Screen Digitizer图片
产品
$39.99
这个答案有帮助吗?
得分 1
6条评论:
No, it's connected alright. The digitizer that II installed works just fine, and the LCD is the original. It worked before, but after the replacement it has a grey stripe.
完成的
You could try disconnecting the display cables, disconnecting the battery, re-connecting the battery, then re-connecting the display cables. Sometimes this works. It's called cycling the battery
完成的
It doesn't seem to work. I will try to avoid disassembling the whole iPad.
完成的
Ok, well. I'm going to guess its the part that's the issue. Try using a quality part, like the one I suggested earlier
完成的
I only replace the digitizer. The LCD is original. Even when the digitizer is fully disconnected, the gray stripe is still there.
完成的
显示更多的1条评论
添加一条评论
Your lcd was broken during your digi replacement. That's what they look like (sometimes) when they're broken.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edvin Jacobsson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 219
