跳转到主内容
修复你的物品
维修的权力
商店
The LG G Pad 8.3 is a tablet created by LG Electronics Inc. that weighs 11 ounces, has 16 GB of storage, and has a 8.3 inch screen.
21 个问题 查看全部
Why am I not hearing any sound?
I'm not hearing any sound from my device, LG G Pad 8.3 even though the volume is turned up! How can I fix this problem?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
已选择的解决方案
Try turning the volume up by pressing the volume up button on the side of the tablet. If this is not working, increase the volume through the sounds settings using the touch display. If this method works, you have ensured that there is an issue with the volume buttons and should consider replacing the volume control buttons.
If this is not the issue, you may considerreplacing your speakers.
*speakers on this device have been known to under preform
LG G Pad 8.3 Speaker图片
指南
LG G Pad 8.3 Speaker Replacement
难度:
中等
20 - 25 minutes
LG G Pad 8.3 Volume Control Buttons图片
指南
LG G Pad 8.3 Volume Control Buttons Replacement
难度:
简单
10 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Helen Cho 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 172
