跳转到主内容
修复你的物品
维修的权力
商店
The LG G Pad 8.3 is a tablet created by LG Electronics Inc. that weighs 11 ounces, has 16 GB of storage, and has a 8.3 inch screen.
21 个问题 查看全部
Why can't I use the internet?
My LG G Pad 8.3 says that I am connected to the internet, but I am unable to browse the web. How do I fix this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
Ok! Is this happening only on 1 device or more than one?
If its happening in all the other devices then its obviously an issue with your Modem or ISP!!
If its only your LG G Pad having this issue. May be there is an IP conflict. You have to reboot your modem. If it still doesn't work then you have to reset the modem which will reset the WiFi settings as well meaning you have to reconnect all the other devices as well. Also check your modem how many devices can be connected some are limited to 5 devices at one time or 10 devices at a time. so check how many devices are connected. Hope this helps!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raenicia Haworth 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 76
