跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
464 个问题 查看全部
Turns off with popping sound when moving the 3D depth slider
Hey! I replaced the charge port on a 3DS today and now when I turn it on and move the 3D depth slider up a little there is a popping sound and it shuts off. Could this be something to do with one of the flexes inside? I checked them all and they seem ok with no damage. Has anyone seen this problem before?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I managed to solve this issue a while ago by replacing the speaker flex cable that runs through the hinge on the device. It becomes damaged very easily from opening and closing the lid.
这个答案有帮助吗?
得分 0
添加一条评论
The 3ds depth potentiometer is connected to the speaker flex ribbon connector which connects here http://www.consolezombie.com/Images/3DS/...
the replacement is very difficult. the speaker flex is like 3 dollars but you have to solder your own speakers. if that one flex is broken i bet the other might give out.
my suggestion reseat the ribbon connector for the speaker wire. And if that works then dont close your 3ds anymore.
dont even go into the top lcd parts unless you watched several videos and already purchased replacement parts and have fixed phones before. the cables have to be wound up to fit throught the hinge part difficult and the other hinge has a lock part.
ps careful when lift in sd card port u dont want to life the metal underneathe it. you dont need to do that. but if you do i suggest putting the screws back under the sd card slot to hold the metal part down while you lift off the sd card from the adhesive. only need to do this first time
这个答案有帮助吗?
得分 0
添加一条评论
I have not had this problem but have you had my problem check out mine. I suggest going to the store and asking them to look at it. if that doesn't help return it and get a new one. that's all Ive got but i hope it helps.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
craigad24 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 320
