跳转到主内容
DirftHD 720相机是黑色,3.5英寸长,和.32磅。 它主要是为了骑自行车者或安装到摩托车手的头盔上。
4 个问题 查看全部
问题已关闭
Why won't my screen turn on?
I got my Drift HD 720 out of the box, I'm ready to use it, and I go to turn it on . . . screen stays black. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you made sure to turn on the device? If that does not fix the problem, have you checked the battery to make sure it is inside. If none of these work, refer to the replacement guide on battery replacement.
这个答案有帮助吗?
得分 0
添加一条评论
Have you pressed the power button? If not, then do so. If that does not resolve the issue, then check to see if the battery is inside. If the issue is not yet resolved, then refer to the battery replacement guide.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 145
