跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
Is the display glass on an iPhone 6s Compatible with iPhone 6?
Can the display glass for an iPhone 6s be replaced with the display glass for an iPhone 6? Are they compatible? Mine is less than a week old and already cracked.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Always take it to Apple. Warranty or not they will fix broken screens for $100. You never know what type of LCD you're going to get on eBay or sham "we fix phone" shops.
完成的
添加一条评论
4个答案
已选择的解决方案
Well first off, you can't actually just replace the display glass on the newer iPhones. They've got a fused display, so you'll have to replace the whole thing. (unless you've got some specialized tools)
As for using a 6 screen on a 6s screen, I know for a fact there are dimensional differences, and the fact the new screens have the extra 3D Touch layer, which you'd be missing by using a 6 screen. I can pretty definitively say this wouldn't work well if at all.
So you've got a couple options, you can wait for replacements to start being sold (actually there are some for sale on eBay but they are very expensive, like 400 bucks+) or you can go through Apple. In your case, this might actually currently be the cheaper option. You've still got your 1 year manufacturer warranty, so that would reduce the cost of the service right off the bat. If you picked up Apple Care you can use that as well.
这个答案有帮助吗?
得分 4
添加一条评论
not compatible, the screen clip is diffrent to begin with and many more differences
这个答案有帮助吗?
得分 3
1条评论:
many differences? Such as? I though iP6S glass is about 3 mm bigger than iP6 glass.
完成的
添加一条评论
It is compatible because I just did it on my sister's iPhone (I accidentally ordered the wrong screen and only noticed it when i went to check the 3d touch and it wasn't available.)
I wouldn't recommend it as the iPhone 6s screen and digitizer is $70 more than the 6.
这个答案有帮助吗?
得分 0
1条评论:
How did you do it? Aren't the connections different?
完成的
添加一条评论
na my yg don't work fam
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Klaus1Eleven 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 27,124
