跳转到主内容
修复你的物品
维修的权力
商店
The Xiaomi Mi 4 is the fourth generation of the Mi line of smartphones produced by the Xiaomi Technology Company. It comprises of the latest technology that all phone companies have to offer in the world.
58 个问题 查看全部
Can I order a new front camera and install it myself?
The front camera for the Xiaomi Mi4 is damaged and needs to be replaced. Purchasing and installing it is a viable option in solving this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
You can install a camera yourself however it will require specific tools so as to not compromise the device. Spudgers to remove the back and a specialty screw driver (Phillip's Head Screw Driver 3.0) to remove the tiny screws from the inner frame. After removing the inner frame, use a tweezer to detach the camera connector and replace it with the new one that you have ordered. If you have other issues please refer to Xiaomi Mi4 Troubleshooting.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Pendeergraft 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 176
