Can I increase hard drive capacity?
Can I increase the storage capacity of the hard drive? The initial capacity seems too small for what I need and would like to increase it.
The ElitePad comes with 2Gb of RAM and Hard drive sizes vary from 32/64 Gb. If more space is needed it is compatible to external hard drives that can be connected to USB ports on the docking stations or the detachable keyboard.
这个答案有帮助吗?
You could use apps like Google Drive and Drop Box to store and access your information on a cloud system. You "expand" your memory storage and are able to access that info on other devices!
这个答案有帮助吗?
The Elitepad has a microsd slot hidden under the cover symmetrical to the volume buttons. put a large microsd in there and you are away
这个答案有帮助吗?
No its built into the motherboard and you have a SD card slot that can go up to 64gb that's it.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 3,623
1条评论
The eidt bade work when concted to charching divice but not work when remove from it
由 almammory 完成的
