跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
Is there a wiring diagram?
I had to take my Starbuck's Barista Espresso machine apart. The problem I was having was the big handle and silver filter cup that you put the espresso grounds into, well when I would put the grounds into it and then you have to lock it in place before you start, when it was locked in place, it wasn't sitting right so, I ended up taking it all apart to clean it out thoroughly. When I put it back together, I think I got some wires put back in the wrong places because although the power light comes on, it heats up, but it's not working correctly. I just want a wiring diagram so I can make sure I get it put back together the right way.. I miss using it. Can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Michael Renville, try this
这个答案有帮助吗?
得分 7
4条评论:
Many thanks!!!!!!!!!!!!!!!!
完成的
Yes, this helped to put my machine back together!
完成的
I need to know the correct position of wires as I plug them back into the motherboard, can you show images?
完成的
@meanerone916 sorry but not available anymore. 7 years is a long time ;)? What are your issues with your machine?
完成的
添加一条评论
添加你的答案
Michael Renville 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 1,515
