跳转到主内容
修复你的物品
维修的权力
配件 & 工具
How to put a key back on?
I have the Mid 2009 MacBook Pro. I spilled a little bit of juice on my keyboard, and the enter key was sticky. I watched a few youtube videos on how to remove the key for cleaning, but when I actually pulled the key off, the white hinge part came off with the key. In the videos I watched, the white hinge part always stayed on the actual keyboard. I don't know how to get the white part and the key back on now. Thank you in advance.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
2个回答
已选择的解决方案
The white scissor hinge will need to be carefully removed from the key and replaced back into the keyboard, and after that the key cap can be replaced. Taking time to study how it all fits together and being gentle with the parts will prevent damage to the clips.
这个答案有帮助吗?
得分 0
添加一条评论
Simply lay the key in the correct direction on the keyboard (Don't put it upside down; Upside down letters on a keyboard aren't fun)
Once the key is just laying in its socket, simply press the key down, as if you were typing. Don't push too hard though. If you hear a click, the key is back in its place.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isabell Eckard 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 9
过去的30天: 31
总计 2,204
