跳转到主内容
An android smartphone released by BLU Products in December 2013.
35 个问题 查看全部
phone mute won't turn off
the phone mute is stuck on, ie there is a angle line drawn thru the microphone icon and of course my called end can't hear me. tapping the microphone icon does nothing. My blue tooth head piece works fine.
this happens even tho phone volume is turned up all the way and the blue tooth is shut off
if the microphone is broken this will be my 3rd messed up blu phone. I guess they can't deliver the quality needed at the very low price they charge for the feature rich phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
nice try , I guess its worth a try to remove battery but it DID NOT WORK for my case, guess I will have to call BLU and go through the annoyance of a factory reset to see if that will fix the problem, will try to remember to post results of BLU tech support suggestion
完成的
there is an option in settings to do reset the phone by your self
完成的
添加一条评论
2个答案
最有帮助的答案
Hello BB,
Remove and reinsert battery to restart your phone and see whether it works as normal
这个答案有帮助吗?
得分 1
添加一条评论
Resetting and removing battery does not fix!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bb 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,154
