Why won't my DXR-5 charge?
If you are having trouble charging the DXR-5, the solution is here.
Using a dry cloth, clean the interior metal plates in the battery slot. Make sure the battery is touching the metal plates (terminals). Ensure that the AC adapter is properly inserted into an outlet. If the device still fails to charge, use the camera adapter to see if the unit charges. If the camera adapter works, then this implies that the AC adapter needs to be replaced. You can contact the manufacture by following this link: http://infantoptics.com/contact.php
or you can check the troubleshooting page at:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 8,252
