跳转到主内容
Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
22 个问题 查看全部
Why are my hinges loose on the headphones
My beats solo hd they fold when i move around they dont stay firm
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
blade6462, loose hinge pins can cause this. Remove the cover plate on each side and you will see how the pins are inserted. It is possible that either they are worn or the holes where the pins go through is starting to wear out. Sometimes you can fix this by replacing the pins with slightly larger ones.
这个答案有帮助吗?
得分 0
1条评论:
Beats studio loses from left side hing is ok but hing connect to band from there its loses what i do now :(
完成的
添加一条评论
Like
i like beat
Like
i like beat
这个答案有帮助吗?
得分 0
添加一条评论
how do i fix this problem for my beats because i tried everything and nothing works.One side is opened!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
blade6462 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 55
总计 14,132
