Can't open back case to remove dust from fans
Got all the screws off, but can't seem to pull the bottom casing. I can partially lift the casing near the fan side, but something seems to be holding the case down from the battery side.
There are magnets still holding the bottom panel to the chassy. Make sure all 10 screws are out and lift harder.
这个答案有帮助吗?
Pop it right off. Had to be a bit more forceful I guess.
Make sure you lift from the vent side as there are 2 clips that hold it in place also make sure you remove all 10 screws
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 83
