跳转到主内容
修复你的物品
维修的权力
配件 & 工具
The Acer Aspire One 722 is a diverse netbook that was released in July 2008. The Acer Aspire One 722 is an 11.6 inch netbook that comes in a sleek black or blue color. This netbook weighs in at 1.46 kg, which is the typical weight of a netbook of its size.
10 个问题 查看全部
Replace key or entire keyboard?
How do I replace the keyboard? Do I need to, or can I just replace the broken key?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
I have never had a laptop key button stay repaired for long. If you want to use the built in keyboard I'd suggest that you replace it. Amazon has them forsale new and used ones.
http://www.amazon.com/Eathtek-Acer-Aspir...
Another option I can suggest is that you get either a USB wireless keyboard and just not use the onboard keyboard. eBay has a nice one for $6.99 shipped (sold through Best Buy)
http://www.ebay.com/itm/Insignia-Wireles...
这个答案有帮助吗?
得分 0
添加一条评论
@Garry Colbert I would suggest taking a look at the keyboard replacement guide here:
Acer Aspire One 722 Keyboard Keys Replacement
If that doesn't solve the problem you could always try an external keyboard which should do the trick!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garry Colbert 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 573
