跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Why is the ipad intermittent? It charges but somtimes it dies.
It works perfectly and sometimes it suddenly dies. I tried opening it up and replaced the glass and also put the LCD into another ipad and it works all the time. No luck. Sometimes pressing on the glass near the connector brings it back to life. Nothing visible on the board near the connectors, when inspected at 100X.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
When you say " it dies" do you mean that the LCD goes blank but there is still activity (sound) occurring?
Or do you mean that it shuts off and needs to be rebooted? If it is the latter, I wonder if the battery connector is loose? Try tightening the screw on the logic board where the battery connects.
这个答案有帮助吗?
得分 1
11条评论:
I measured the charging current and voltage. It charges normally whether the screen is working (and the rest of the Ipad) or not. The charging is normal when it lights up or not. It looks like a connection from the LCD screen to the logic board is intermittent.
完成的
Sounds like a board level repair. If you are looking for someone to tackle it, JessaBethany on this site comes highly recommended.
完成的
Thanks. How do I contact JessaBethany?
完成的
mendonipadrehab.com is her website or search users on this site.
完成的
It now has changed to a different situation. The ipad only lights up when both buttons are pressed and only stays on for an instant. The left edge of the LCD has alternating dark and light areas. It looks like there is a problem with the video signal that feeds the LCD. It still communicates with itunes. Any suggestions?
完成的
显示更多的6条评论
添加一条评论
Hello Doc ken,
Restore the device and update it to iOS9
Here you can find the support document
这个答案有帮助吗?
得分 0
2条评论:
I already updated it to IOS9 and it didn't fix it.
完成的
It is a hardware problem. It goes back on or restarts when the area of the connector is pressed on the LCD face through the glass. Is there a way to see the underside of the LCD connector?
完成的
添加一条评论
添加你的答案
Doc Ken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 171
