跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch screen unresponsive when touched but 100% visible
I replaced the screen on my gold 6 plus, I decided to put a black screen on Iit and everything went well until I turned the phone on and the screen was unresponsive to touch. Before complete installation I did test the screen and it worked . The screen has light lines running down the screen please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Does the home button work?
完成的
I didn't attach the home button backing plate yet because I have a stripped screw and ordered a new plate, but the touch id was still funtioning
完成的
添加一条评论
4个答案
已选择的解决方案
I would take the phone apart again and get it to were it worked before then re assemble slowly and with care checking when possible if it works to know when things go wrong.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Sounds like the digitizer flex cable or socket on the board may be damaged. I would inspect those areas under a microscope.
这个答案有帮助吗?
得分 1
2条评论:
Could also be a short , did you put all the insulating tape back on?
完成的
When I extend the flex cable while it's plugged in the screen becomes clearer, but still lines going through
完成的
添加一条评论
Your digitizer flex isnt properly plugged in most likely.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
Touch input all jacked up after multiple screen replacement attempts
^Try this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 330
