跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 个问题 查看全部
The volume is at max and can't be decreased
seems like the volume up button always gives contact to put the sound at max. Sliding the volume down in dsi sound studio helps, but as soon as you release the slider the volume gets to max again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
I noticed you never got an answer to this. Are you still having this problem?
完成的
Did either of you get an answer to your problem or get it fixed? My sons systemis doing the same thing. Thanks.
完成的
Did I miss understand? I thought over on Meta it was decided to vote these into comments, not Questions. The problem has never had a accepted solution in almost 9mos. Do we want to have another Question the samet?
完成的
添加一条评论
2个答案
已选择的解决方案
Your "up" volume button is stuck down; check to see if any crumbs or dirt have gotten in there. You might need to replace the SD card slot and volume control assembly.
Nintendo DSi SD Ribbon Cable图片
产品
$24.99
这个答案有帮助吗?
得分 1
添加一条评论
My thought would be that the slider button is off track and no longer adjusting the slide switch on the motherboard. You could take it apart to confirm this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joost Appelmans 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 26
总计 5,625
