跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Is this water damage salvageable?
I left my macbook our in the rain during a pretty strong rainstorm. Now it won't boot up or charge. :(
There is minor/medium corrosion scattered all over the left side of the logic board, and more on the MagSafe DC-In board.
Is this water damage salvageable? Should I even bother buying replacement parts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
Most things are fixable but its a question if you have the tools and knowleage to fix them. What you would want to do is first run the board through an ultrasonic cleaner to remove all the corrosion. Then you want to get the schematics and board views for the board and begin testing every power rain the the machine. Once you find what rails are missing you will then need to trouble shot the circuit for that power rail and find the problem components and replace them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christopher Jaynes 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 232
