跳转到主内容
苹果的iPod Touch第六代于2015年7月发布。
143 个问题 查看全部
Is the lcd assembly the same as the iPod touch 5th generation?
I was just wondering if the ipod 6th generation lcd assembly is the same as the 5th generation assembly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
3条评论
just put an ipod 5th gen lcd on a 6th gen - works great.
完成的
Thank you! I was just looking for the answer to this question! :)
完成的
one question...I have ipod 6 with display problem.can i replace the display with ipod 5th gen(Without rear camera version?).
完成的
添加一条评论
2个答案
最有帮助的答案
第六代 iPod Touch 拆解
Yes it is
这个答案有帮助吗?
得分 4
添加一条评论
Ipod touch 6 screen doesn't have the same front camera emplacement...so we can't say that's identical but screen work.. that's just not the same bezel.
After my test i can say ipod touch 5 is not compatible with "original" ipod touch 6 screen (not same camera bezel as the 5th)
But ipod touch 5 screen is compatible with ipod touch 6 !
这个答案有帮助吗?
得分 3
2条评论:
Hello! I was reading about the iPod 5th gen LCD didn't have
exact same camera bezel as the 6th gen.1or something like that? But then the LCD is compatible though?
So what s that then? Like if I use LCD from 5th generation model to replace 6th generation LCD, would it mean that the camera won't function afterwards or something like that?? OR......??
完成的
The camera will work. All 5th screen will work correctly camera included but you just can't fit 6th camera on 5th screen because thats not the same hole.
The best way is to keep 6th bezel and glue it on 5th screen ...then rebuild it
完成的
添加一条评论
添加你的答案
Esther Kent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 7,572
