跳转到主内容
Support for percolators manufactured by Farberware.
35 个问题 查看全部
When I plug the urn into an outlet nothing happens?
When I plug my faberware coffee Millenium FSU236 urn into an outlet, the device won't work. What might be wrong with my device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My wife bought Farberware coffee make 3days ago it plugin light come on but nothing.. Will not let you choose cup, ground, or k-cup..
完成的
添加一条评论
3个答案
最有帮助的答案
Peggy, a number of things could be wrong, so you should start with the simplest things (your statement that the "device won't work" implies no heating at all, which implies an "Open Circuit"):
1) Is the outlet working properly? Check it by plugging something else into that outlet (a lamp, for example) to test the outlet. If the outlet checks out OK, then....
2) Next, inspect and check the cord - if you don't know how to check the electric cord for continuity with an electrical tester, then simply replace the cord with a new one. If the new cord doesn't fix the problem, then......
3) The next steps would require disassembly of the unit to see why and where there is an "open circuit" somewhere inside the unit. It does not sound like you could tackle the disassembly and repair of the unit - some electrical knowledge and testing capability is required.
That is a very nice coffeemaker and is worth fixing. You have not provided much in the way of symptoms; just that the coffeemaker does not work. Does the urn heat up at all? Does the cord get warm?
Zenon
这个答案有帮助吗?
得分 1
添加一条评论
Im having the same problem. I’ve narrowed it down to the AC power cord. The urn itself is usually pretty durable. So unless you dropped it, or got the whole exterior wet, the unit itself should be fine. Heres a link for the percolator electrical Cord https://www.amazon.com/dp/B000QFDMQI/ref...
这个答案有帮助吗?
得分 0
添加一条评论
This is called an open circuit. A number of possibilities come to mind:
1) Bad cord (cheap fix)
2) Bad wall outlet (easy check - plug working lamp in and also try plugging coffeemaker into another outlet)
3) Circuit breaker has tripped (could be one-timer or an indicator of a more serious wiring or breaker problem). Circuit breaker normally controls multiple outlets, so check other outlets.
4) Next checking options involve disassembling coffeemaker bottom, looking for “open circuit” inside: loose connections, broken wiring, defective thermostat, defective heating element (not common), broken plug pins etc. Will need Multimeter and some expertise to do this checking (or someone who has this expertise).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
peggy libby 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 77
总计 3,597
