跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
416 个问题 查看全部
50 panasonic Viera model no.TC-P50C2 won't turn on. red light blinks
red light blinks 5 times. I have done unplugged, cleaned, & blow dried..Nothing. I also tried plugging it in a dif outlet.. HELP ..Anyone? Tammy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 51
74条评论
different model....but did the trick....thanks
完成的
Its Friday night, tv not working, was so brassed off, thank you for the fix!!!
完成的
Thanks for providing the trick. Worked great!
完成的
My Viera TC-P42x5 would not turn on either. No lights nothing. I took the advice and held the power button for maybe a little longer than 60 seconds and it came on. Great advice thank you. Super Bowl Sunday.......
完成的
i got a panasonic tv its not turning on it just shut down and it is not turning on someone please help
完成的
显示更多的69条评论
添加一条评论
7个答案
已选择的解决方案
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv. Hope this helps
这个答案有帮助吗?
得分 120
129条评论:
Thanks will try.
完成的
well jimfixer thank you very much you are the ruler yes
完成的
No lu ck so far. Heck the tv repair guy i hired cant ever figure it out.
完成的
First suggestion worked! Thanks you SO much...
完成的
Power + volume button did the trick for me ... I get the same issue whenever someone hits the standby button, but it will reset again, and otherwise we just turn the TV off via the main power button (which is better for the TV and power usage anyway)
完成的
显示更多的124条评论
添加一条评论
Do 1 & 2 together.
1] Press and hold in the on/off switch.
2] Press and hold the red button on the hand set for 30 seconds.
This will reset the PANASONIC TV.
This solution cost my £85 and the techy was in and out of my house in 5 minutes!
Robbery.
这个答案有帮助吗?
得分 35
55条评论:
This worked a treat on mine! Thank you
完成的
Hey, was panicking, as I am hopeless with tech. Tried everything to get my tv to switch on. Eventually found your post and it worked . Fantastic advice. Really appreciated your advice!
Thanks. Rob.
完成的
really was panicking a bit but your method helped a lot .thank you mate.
完成的
THANKS !!! it worked !!! I was panicking here, Friday evening , and no tv ...
Thanks fro sharing your experience and solution with us xx
完成的
Thanks to Paul Brabbins I saved myself £85. Problem was with Panasonic TX-L32U3B in the UK. Using the remote to try and turn it on the red light would flash but never turn green. Before searching the web I tried all the obvious stuff. Paul's remedy worked first time and in less than the 30 seconds he mentions. Great! Thanks Paul.
完成的
显示更多的50条评论
添加一条评论
ttibal, get the multimeter out:-)
5 blinks condition can be caused by:
Missing P5V
A short of the P5V
A short of the Vda line (Note: missing Vda from the P board does not cause 5 blinks)
Wrong diagnostic by the D board
check the voltages as indicated. Attached documents will show how to test each one of the boards for the 5 Blink error code.==>> LED-5-Blinks.pdfLED BLinks 5X <<==
这个答案有帮助吗?
得分 4
5条评论:
i have a Panasonic TX-L50B6B,when i press the power button the green light comes on but the picture wont come on,after about 5 seconds the green light goes off and the red light comes on and starts to blink continuously
just now by leroy rowe
完成的
That's exactly what mine does. It's driving us crazy. Sometimes it takes 7 or 8 goes to turn it on.
完成的
Brilliant! Thank you. Step 1 didn't work so tried the next step and held the the power button in for 20 seconds and bingo!
完成的
Where did you find the pdf for the LEDS i have 7 blinking lights... I found a YouTube video but after the sc board is disconnected and the tv is turned back on i have a solid red light and all the videos have 6 flashing after turning tv on with disconnected sc board... So therefore it's their sc board but not mine... Need to find site for pdf... HELP ME PLEASE
完成的
I tried your 60 sec. trick, kicked right off. Thanks so much. I am saving this trick in case it happens again, but in the meantime I keep it in standby mode. Makes a good nite lite!
完成的
添加一条评论
You have to unplug the tv for at least an hour. (The longer the better) after that, you have to hold down the power button from the tv (not the remote) while the tv is still unplugged for 60 seconds after 60 seconds continue to hold down the power button and plug it in. Keep pressing the power button for another 60 seconds. A blue or red light depending on the model should pop up. If it didn’t work in that time frame you can try and hold it down longer.
If that didn’t work, then you have to hold down the power and the menu button on the tv at the same time while the tv is plugged in until a blue or red lights pops up and the tv turns back on.
Hope this helped you guys!
这个答案有帮助吗?
得分 3
8条评论:
I have somewhat same issue but I'm getting no lights at all should I try the same methods
完成的
Thank God first trick work perfectly power on plus volume up yeah done the job. Thank you huge
完成的
I have the same issue with my 50 inch. It shut off by itself and the red light flashes 10 times. I have tried unplugging it, holding the power button, Power and volume buttons. Nothing.
完成的
Same %#*@ thing happened to us.... not sure what else to do. I have unplugged at the wall, held the power button down. Still yellow comes on but wont kick over then defaults to red blinking lights. Help!!!!
完成的
I have no lights, no power at all, no warning just all of a sudden shut off.tried some of these steps nothing
完成的
显示更多的3条评论
添加一条评论
Turn the TV off, then press the TV on button and remote on button at the same time. I guarantee it will work.
这个答案有帮助吗?
得分 3
6条评论:
Green light on then turn blinking red
完成的
Saved me from buying a new tv, tip worked great!!!
完成的
Hear the relays kick on,red light goes to flashin 10 times?????? Anybody?????
完成的
You are a genius!!!! You've saved my life and my sanity, I'm in isolation and I'm alone, I love you!!!!!
完成的
I've been dealing with this particular issue on this TV for years, trying all kinds of suggested solutions. This one worked like a charm! Thank you!!
完成的
显示更多的1条评论
添加一条评论
2021 and your still fixing TVs. Thanks very much power and volume worked for me here in Scotland
这个答案有帮助吗?
得分 0
1条评论:
Worked for me here in Scotland. Legend
完成的
添加一条评论
My Chromecast was causing the problem I think. Holding the power and top button F on my TV for 30 seconds worked. So try different button combos if nothing is working. I had flashing red light but no green.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ttlbal 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 94
过去 30 天: 458
总计 473,950
