MacBook Pro Is Beeping Constantly And Won't Turn On
Its different question MacBook Air 1304 Is Beeping Constantly not starting.
The big question is: What does "constant" mean?
Beeps at startup usually indicate a hardware error; the pattern of beeps tells you what type of error is causing the problem. Apple has a tech note describing the patterns and how to repair the problems:
Mac computers: About startup tones
The two broad categories are RAM (memory) problems and EFI ROM (firmware) problems. If it's RAM, you've got a big problem; the memory in a MacBook Air is soldered to the logic board, and the logic board will have to be replaced. If it's EFI ROM, the tech note describes how to do a ROM recovery.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,179
Is there a pattern to the beeps?
由 mayer 完成的
