跳转到主内容
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 个问题 查看全部
Can't increase brightness after a screen repair
Hi Guys,
I'm new here. My problem is Last day I have repaired my Xperia Z screen assembly. After repairing it I found that I can't adjust the screen brightness. The dispaly is at it's lowest brightness if the brightness level is 0 or if it is 100. I don't why this happens. I did a hard reset. But it doesn't solve the problem. please help me to resolve this problem.
Thanks,
Renjith R
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
Hi Renjith,
Any success with this issue? I have the same problem here.
这个答案有帮助吗?
得分 0
添加一条评论
Same here. The back of mine has been broken for a while but the actual screen is fine. Now the brightness doesn't change unless I set it to be different and then restart the phone
这个答案有帮助吗?
得分 0
添加一条评论
Hello, same problem. Any solution?
这个答案有帮助吗?
得分 0
1条评论:
Go to display settings and turn off smart backlight control. This worked for me
完成的
添加一条评论
Same Problem :/ please help me
这个答案有帮助吗?
得分 0
添加一条评论
Same here z2 just cant get it bright enough, and it now has a slight green tint.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Renjith R 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 13
总计 2,722
