跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
132 个问题 查看全部
Dim Screen, brightness adjustment maxed out
Hello all, I'm working on a Samsung Tab 4, wifi only with screen brightness issues, specifically, the screen image can not be seen unless in a dimly lighted area, when in sunlight the screen is dark - even if I shade the screen with my hands, the screen image cannot be seen. The brightness control is turned all the way up.
When the image can be seen, the brightness is consistent , no dead pixels and the image is clear(not blurry). Any ideas on what I can do to increase the brightness?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Check and see if your power saving mode is on and is your battery almost dead like at 4%
完成的
I have the same problem. My power saving mode is off and my battery is at 80%.
完成的
添加一条评论
2个答案
最有帮助的答案
@meepfish1 has a relevant suggestion. Other than that, what is the history of the device? Has it ever had a screen replace or other work done? Its possible there is an issue with the LCD or with the board itself, in regards to the backlight circuit. This is usually the case when work has been performed, the device has been damaged in some way, been near water, ect
这个答案有帮助吗?
得分 1
添加一条评论
Unclick auto brightness
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 2,737
