跳转到主内容
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
91 个问题 查看全部
问题已关闭
Power but no output.
When I power it on you can hear it working. Disc spins, fan blows, but there's zero output to my tv. Is there anyway to determine if the problem is the optical drive assembly or the mother board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I know I'm a girl, but I'm aware of the process of elemination when trying to solve a problem. Of course I checked those obvious things first. Thanks for condescending though!
完成的
添加一条评论
1个答案
Julie Henderson, before you do anything else, check your AV cable. Make sure that you have the right cables, connected properly and that your TV is set up properly. No reason to believe just yet that you have a bad drive or motherboard. Start with the simple things and let us know what you find.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 72
