跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1622 个问题 查看全部
问题已关闭
AirPort/Bluetooth assembly, minding the fragile antenna Cables
when I was changing the cable one of the Airport/Bluetooth cable broken .
Can Any one tell me how much it cost and where can i get that from, the broken cable is from wireless side
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ouch! Not good.
If you are speaking about the antenna cables they are part of the display lid assembly. You would need to take the lid off completely following this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Display Replacement and replace the complete display assembly as Apple doesn't sell the discrete parts within the lid. The other option is locating a junker to steal the parts from. But you may find just replacing the lid assembly will be easier and less risky.
Frankly, if you lost one of the WiFi antennas then why don't you locate a USB dongle and work around the problem. While its not ideal it will get you there.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 94
