跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
I can't use microphone in speaker and Siri
I can use my iPhone for recording voice notes, videos, shazam, calling with the phone in my ear, record voice messages in WhatsApp but when I try to make a call over Speaker or trying to use Siri, the michophone doesn't work. What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
An iPhone 6 has 2 microphones, the one in the bottom is used for normal voice calls, shazam etc...
The other one is on the top next to the front camera (it is one assembly with the camera, sensors and earspeaker cable).
replacing that assembly could solve the problem.
这个答案有帮助吗?
得分 1
添加一条评论
Try a new front camera.
这个答案有帮助吗?
得分 0
1条评论:
I tried and not working. My microphone does work on another device.
完成的
添加一条评论
I had the same problem too. The store replaced my iPhone 6. Now after 4 months, the new replacement is having the same problem again. Maybe this is a mishap of iPhone 6 units.
这个答案有帮助吗?
得分 0
添加一条评论
Maybe the anti dust mesh is not lined up correctly...which means every time you install an new camera even though it's working it's being cancels because it's not aligned in the phone correctly..what I would do is take the screen out and take the camera and earpiece out and check and see if you could see both holes one being small and one being bit larger.
这个答案有帮助吗?
得分 0
1条评论:
[image|690479]
I would check not only out side but inside to make sure it looks aligned
完成的
添加一条评论
Example
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jairo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,115
