跳转到主内容
修复你的物品
维修的权力
商店
型号A1318,闪存容量:32及64GB
397 个问题 查看全部
IS water damage invisible on logic board?
Hi-
Still trying to fix this sucker.
Dropped in toilet three days ago.
Let airdry for 6 hours.
Plugged in to PC (I know, dumb). It restored.
Let air dry 2.75 days.
Removed glass. THe LCD has a black spot the size of a dime and one streak.
I am looking at the logic board to see if it has water damage.
I don't see any signs of corrosion. Can it be invisible?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
the black spot on the display is normal for a broken one - but for now - wait until you buy a new one!
fluid damage ins't invisible - but sometimes it's tiny - the parts in the ipod touch are sometimes pretty small and you need a magnifier to see if something is shorted.
don't forget to look under the logic board - most people are only looking on the top side of the board!
get some isopropyl alcohol mith more than 90% and a soft paintbrush, use it to clean the board and the connectors - be careful - those parts are very fragile!
let it dry (1 day should be enough) - don't use a hair dryer for that!
reassemble it and try it again.
good luck
这个答案有帮助吗?
得分 1
评论:
Ugh. No I am in UK. I went to three "chemists" what they call pharmacists, and no alcohol. They act weird, like I am buying bomb components. Hardware store neither, but she did tell me that others had been asking. This is some odd little side mystery.
完成的
you can also look out for a good electronics cleaner. i searched amazon.co.uk a little bit - something like this one would be good: CLICK. maybe you have an electronics store where you can get parts like capacitors, resistors and so on - those stores have something like that
完成的
i bought some at boots-on a special order, they were a bit surprised! try maplin
完成的
添加一条评论
添加你的答案
Sunshine 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,472
