The mains fuse inside the amplifier and I found R145, R170 melted
The amplifier keeps blowing the mains fuse and i found R145,R170 are melted on the pcb can you help me fix this problem?
Step 1: check output stage.
2:power supply components.
3: check board for any leaking cap’s.
这个答案有帮助吗?
If these are glass fuses chances are you have a output transistor or transistors that has went bad. These devices are in place to provide sound in the speakers through a chain of other components. It will need to be looked at and diagnosed by a professional tech. This is something you may not be able to do yourself for reason of LETHAL HIGH VOLTAGES and lack of equipment and or knowledge.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 430
1条评论
teque516, post a couple images of your board with your question.
由 oldturkey03 完成的
