跳转到主内容
加入维修社区 - 创建账户
Amazon's second generation e-reader with a 6'' e-ink display, five-way controller, and QWERTY keyboard.
Back button doesn't work
The back button on my Kindle stopped working. When I press it, it doesn't click. I think that at one point I was putting on hand lotion and a drop of hand lotion fell on that spot. Although I wiped it off quickly, I'm thinking that it may have seeped through the cracks and that is what is causing the problem. My Kindle is out of warranty. I see that the Kindle can be taken apart, but I'm afraid to do so, because everything else works fine and I'm afraid that if I take it apart, I'll mess it up. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If you're careful all you have to do is follow the simple teardown which will show you how to access behind the buttons, and you can see what the issue is. If there's residue try cleaning up with rubbing alcohol.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Migdalia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 2,798
