跳转到主内容
The Keurig K75 Platinum Brewing System is a premium single cup home coffee brewing system by Keurig.
21 个问题 查看全部
Stop my timer on my keurig
How do I turn off the timer so my keurig will stop coming on automatically?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
There are two separate timer functions on the coffee maker:
Function one is the auto ON/auto OFF feature. This works by setting an ON time by adjusting the hours and minutes and an OFF time the same way. This is done by pressing the MENU button until you scroll to set ON time and set OFF time, respectively. Use the arrow buttons on either side of the MENU button to set the hours and minutes for each. Push the MENU button once to set. When enabled, the coffee maker will show a set ON/OFF time in the main brew control window. To completely disable this function, set both the on and off times to 12:00 a.m. When disabled, there will be no set on/off time display in the main control window. NOTE: the clock must be set for this function to work properly.
The 2nd timer function is the auto OFF feature. This turns off the coffee maker after a certain period of time (in hours) passes and can be set by continually pushing the MENU button until the display shows auto OFF in the menu. Use the left arrow button to scroll to the desired number of hours until the coffee maker turns off. push the MENU button again to set. To disable this function, scroll through the hours until the display shows OFF. Similarly, the main control window will display whether this function is active or disabled.
Hope this helps... :)
这个答案有帮助吗?
得分 6
添加一条评论
coffee lover, set the brewer to “AUTO OFF” following a specified period of time after the last brew.
a. Press the MENU Button twice to program the Auto Off feature. The LCD Control Center will display the programming options with a small arrow next to “SET AUTO OFF”. From there press through to the menu to set the time as off. Get the owners manual from here Page 11 will show you how to do it.
这个答案有帮助吗?
得分 1
添加一条评论
I found the only way to return Time Set On and Time Set Off is to unplug the Keurig. This seems to reset the menu display.
这个答案有帮助吗?
得分 1
1条评论:
thank you for this comment omg !!!!!
完成的
添加一条评论
Set both auto on and auto off timer features to midnight. The display will then show "off".
这个答案有帮助吗?
得分 1
1条评论:
Setting both to midnight worked.thanks.
完成的
添加一条评论
添加你的答案
Coffee lover 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 32
过去 30 天: 167
总计 42,906
