跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
问题已关闭
New front panel won't stay stuck
I've repaired many ipads now but on a number of them the glass doesn't want to stay stuck down. I've had problems with both the ipad 2 and the ipad mini.
I've tried different things such as using goof off to remove the old adhesive, double sided tape, and even reheating the glass once it's installed and putting weight on it to hold it down while it cools.
Any suggestions for this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Mike,
I struggled with iPads for a long time. Here's what I suggest. After removing your digitizer, use a metal sanding material(think scotch-brite) soaked in 99% isopropyl and scrub the frame surface until it's completely smooth. Then, I use a very high quality tape to apply it, I will link it below. Better adhesive is really the answer. I also find I get better results when I apply the adhesive to the frame first.
After laying down your digitizer, use some plastic clamps and clamp the 4 corners as well as one in the middle on the top and side. Two clamps will go on either side of the home button. Once it's under pressure, heat the screen and allow it to rest and cool for about 10 minutes. I haven't had a single issue after using this method. Also make sure you're getting your digitizer cables folded right. Hope this helps!
http://www.amazon.com/Tesa-4970-Tackifie...
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 7
总计 310
