跳转到主内容
Identified by model number P774A-GR.
10 个问题 查看全部
three tablets need repair for different issues
The red tablet has a cracked screen that is chipping and now does not work. The orange tablet has a gray and black screen but out glass is fine not cracked. The purple Tablet does not move from the start up screen and when you turn it off to restart it does not turn on. Who can I send it to get it repaired.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Lugo, sounds like you need a digitizer for the red tablet, an LCD for the orange tablet. The purple tablet sounds like it has issues with the firmware or the memory IC on the board. This is going to be tough since parts are really not readily available but it does look like some parts can be had at Amazon and/or Ebay. Do a search for CKP774. The repairs are really not bad, just follow these guides to do it yourself. Sending it out for repair will cost you more than to replace those tablets.
这个答案有帮助吗?
得分 0
添加一条评论
The tablet screen is must up and the colder is not right.It look like it is crack but it is not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lugo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 322
