跳转到主内容
4" smartphone manufactured by BLU Products, featuring a dual-core processor, 512 of RAM, and Android 4.0
Why is my phone screen stuck on "BLU"?
How do I fix my phone screen when its stuck on "BLU"?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
3条评论
The phone stuck on blu logo
完成的
Mine was too, until I took off the plastic cover on the screen
完成的
I have the same issue is there a way to get my files before doin factory reset
完成的
添加一条评论
4个答案
最有帮助的答案
try factory reset
Turn off your cell phone.
press and hold Volume Down + Menu button + Power button.
If you see menu of Recovery mode, then release your fingers from the phone.
now select "wipe data/factory reset" using Volume buttons to navigate, and Power button to choose.
Afterwards accept operation "Yes -- delete all user data".
select "reboot system now".
Done!
Remember you will lose all your files and data
这个答案有帮助吗?
得分 3
13条评论:
That didn't work my phone still looping
完成的
then you have to re flash the phone with stock firmware....
完成的
when i do that i don't see factory reset or wipe data
完成的
tell me what you see ... or a screen shot will be much helpful
完成的
I had to call and get mine replaced
完成的
显示更多的8条评论
添加一条评论
It happen to me when my phone was stuck on the blu logo I flashed it and it was back to normal for a few day .It started happening again it stuck in the Blu logo and won't come on I guess flashing it hasent helped what else can I do ?
这个答案有帮助吗?
得分 1
添加一条评论
My phone is too, stuck on the Blu logo and I really upset, because I wish to use that phone but I can't boot it
这个答案有帮助吗?
得分 1
添加一条评论
It's probably just a glitch or your screen froze just power it off and let it cool down then turn it back on
Or if that doesn't work wait till it goes dead then charge it then see if it works then .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nevicki Milton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 13,325
