Drain nipple under carburetor leaks gas when throttle is turned.
When I turn the throttle my drain valve leaks gas at a tremendous rate. I've tried plugging it, but all that seems to do is cause my carb to become flooded.
What could be causing this...I've gone through a full tank of gas in less than half a mile. Also what house is the nipple next to the main fuel line for?
1条评论
Having the same problem
由 Willie Buie 完成的
