跳转到主内容
Kindle Fire,也称 Fire 或 Amazon Fire,是 Amazon 推出的平板电脑。操作系统基于 Android,使用多点触控屏幕。拆卸维修仅需用到螺丝刀和撬棒。
Why the screen won't light up
The kindle is charged the green light comes on but the screen won't light up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I would see if you can see anything on the screen when you get it into the light just right you will need to use a bright source of light if you can then it is a back light issue. if you can not then the problem is ether the screen or the the device itself.
这个答案有帮助吗?
得分 0
1条评论:
the background picture is on but the reading light won't come on. When I push the button to turn the reading on, the green dot lights up for approx 5 sec. and then shuts off while I'm holding the button in.
完成的
添加一条评论
添加你的答案
Felicia Mcfarland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 380
