Why does my gameboy mirco stop at the gameboy screen?
When I turn my gameboy mirco on it works like it normally would but it stays at the gameboy screen. I tried putting other games in and it does the same thing. What do I do?
Did you check that nothing is blocking contacts inside the game-cartridge or in the Gameboy Micro? You can try a little bit of contact spray or to cleanse the contacts first with something like "Kontakt LR" or a similar product. Kontakt LR (www.crcind.com) has a brush included to be able to clean the contacts.
这个答案有帮助吗?
Use a high percentage isopropyl alcohol to clean the contacts on the GameBoy and on the carts.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,396
Does the interface between cartridges and the system appear to be damaged in any way?
由 rab777hp 完成的
are you sure there isnt a lose connection inside the unit
由 Tacotuesday 完成的
