跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Replacement Power button not pressing or clicking
Hi all,
My power button stopped clicking in - when you pressed against it the button never moved and didn't click.
I brought a new power button ribbon cable and replaced it.
When I put the button in and hold the bracket against it the button works and clicks, however as soon as I put 1 screw in the bracket the power button stops clicking and goes stiff again.
I have made sure the power button is in correctly, metal bracket down etc.
Ive tried 2 power ribbons now and they all click, just not when the bracket is screwed in.
What gives?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
try backing the screw that holds the bracket out 1/2 turn to a full turn. Sometimes if they get tightened all the way down it will not click
这个答案有帮助吗?
得分 1
添加一条评论
Try taking the back glass off, fold a small piece of paper and put it under the power button for a temporary fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 66
